No Clutch Pressure Rev 3 turbo
Lost all clutch pressure in my rev 3 turbo.
No visible leaks from the master or slave, is there a common place where these are prone to leaking internally/externally etc??
Re: No Clutch Pressure Rev 3 turbo
Is your clutch pedal on the floor?
If you pull the clutch pedal up with your hand manually does the spring eventually kick in and snap it into the up position?
Same thing happened to mine after sitting for months.
No spring action so perhaps that had given up the ghost.
