ever since i bought my mr2 its had a problem in that the instrument panel lights didnt work
in an attempt to fix this, i have:
1) bought and replaced the old bulbs with new LEDs
2) taken apart the headlight switch, resouldered all souldering points, cleaned all contact points, and made sure the dimmer wheel wasnt cracked.
3) checked all fuses are and relays, all are ok
4) checked all wires, all are ok
5) tightened all connections at the headlight switch so contact is definitely made.
since doing these, there is sign of life with the dash lights coming on if you connect the wires to the headlight switch in a particular way, however, when the dash lights are on, the side lights dont work, and when the side lights are on, the dash lights dont work.
so what im trying to say is that it looks as though i can either have dash lights, or side lights, but not both.
i have searched all over the internet and i cant find anyone with the same problem, i just hoping someone on here can help me.
cheers guys
