I want to drive my car again
Cheers,
Leigh
feral4mr2 wrote:all the 4age variants have the same crank snout, so the crank pulley will fit on either engine/s.![]()
just measure the OD of the pulley to see if it's the same OD as yours.![]()
the 4agze uses a larger OD
(145mm) pulley than that of the 4age
(umm.
cant remember what it was 130-135mm?).
(not that running a different sized OD on a na engine would make a great deal of difference).
ldavies83 wrote:Thanks for that, your absolutely right, just double checked on club4ag.com, 4age aw11 diameter was 131mm(close!) and 4agze was 146mm and there was a whopping 1kg difference between the 2 pulleys in weight!! No wonder you can buy lightened pulleys for the ZE
ldavies83 wrote:icsunonove, your idea about the grubscrews![]()
I fear my technical abilities may not be up to scratch to start drilling precision holes, but I think I see where your coming from!
MartG wrote:The GE just has one pulley which drives the alternator and water pump.
Icsunonove wrote:MartG wrote:The GE just has one pulley which drives the alternator and water pump.
Are you sure? I thought the alternator and water pump were driven by independent belt
(might be totally wrong on that though)
MartG wrote:Icsunonove wrote:MartG wrote:The GE just has one pulley which drives the alternator and water pump.
Googled a pic of the GE and checked before I put that post up, so yes, fairly sure.Remember that on a GE the alternator is at the back of the engine
( ie.
where the SC is on a GZE
Icsunonove wrote:ldavies83 wrote:icsunonove, your idea about the grubscrews![]()
Ha ha ha! There's nothing precision about it at all!!!
Just centre pop a hole on the interface line.Then use a 5.0mm drill and drill to a depth of, I dunno 12mm.
Then tap it M6 and fit and Locktite a grubscrew in.
Do this in two places and bob's your uncle.
Then you just need to remark the timing marks in the new position, that not's difficult either..
Icsunonove wrote:Found knackered pulley that I was told was off a 4AGE.
Here it is:
I am almost certain that the hub is correct to fit on my 4AGZE.So it will fit on a 4AGE.
As you can see it is a double pulley and it appears a belt has been running on both pulleys.
Anyone got any ideas what it's off?
And Kevin, now I see what Paul's on about, I didn't understand how it was constructed, it's totally impossible to do the grubscrew bodge, there's actually an intermediate rubber layer!![]()
