Ran perfectly fine, however my rev counter is dead.
Now I realise the tacho gets its feed from the ignitor after a Google, which is the black wire on the ignitor plug.
I've traced this back to the fuse box.
I also get continuity on one of the black wires there as well so there's no break to that point.
I've followed the st205 bgb and everything checks out
Last resort I thought it must be the capacitors on the tacho, but replaced those and still nothing.
Also swapped ecus and again no change.
I'm running out of ideas??
