ok, so the passenger side headlight bulb has this annoying habit of not coming on properly.
I mean the headlight unit rises into position ok but the headlight bulb is very dull, almost like a sidelight.
Doesn't do that all the time but whenever it suits itself.
Using either dip or main beam has the same dull light glow.
Every time I take apart the headlight unit to get in and try and fix it, it works perfectly by the time I take everything apart to test it.
Bulb works fine, both dip and main.
I've cleaned the bulb contacts, cleaned the connector block but it never seems to be a permanent fix.
Worked perfectly this morning going to work, perfect coming home then heading to and from the gym, dull glow from the passenger bulb.
Doing my head in
Anything else I can look for?
