[Mk2] [Turbo] Manifold bolts
I'm taking my manifold off to get it skimmed, where would you guys recommend buying new bolts for the manifold, sensor, and heat shield from? And also a new gasket? Just want to make sure I get the correct sizes etc. It's a Rev 2. Thanks!
Re: [Mk2] [Turbo] Manifold bolts
Personally, I got mine from Toyota. Easiest option in terms of 'no surprises' when it comes to fitting.
January 2014
May 2015
Still in the garage...
..the only thing I can promise for sure is slow progress.
May 2015
just have this niggling thought that if I rip out the wiring, then the car will never get out of the garage again.
Coo, thanks mate.
I recently bought exhaust manifold studs and nuts from TCB for considerably less than my local dealer quoted and less than the couple of ebay listings i found.
IIRC £19 ish for genuine toyota studs and nuts
Nice one, thanks mate.
