I have checked all fuses, changed relays in the driver's footwell fusebox and they still don't work.
Any thoughts before I dismantle the console?
jimi wrote:Have you checked the dimmer isn't turned right down?
jimi wrote:Sounds like it, all the aforementioned are controlled through the dimmer.
jimi wrote:Linking the 2 wires will eliminate the dimmer, but will only help if the loose connection in in the dimmer.
jemehan wrote:I know this answer, mine does this sparadically, a firm tap on the top of the switch arm on the console fixes it.The light toggle is where the problem is, just replace the swtich on the console and your problem will be resolved.
it is annoying until fixed though!
