I have an MBC fitted, however this has been wound all the way out to its lowest setting.
Before I replaced the cat I was hitting 10psi with the mbc, and before the mbc I was hitting 7 max.
The cat was absolutely ruined.
My guess here is that the mbc's stock pressure is about 15psi(?), but I've seen other people
I also have fuel cut disconnected and the VSV.
