Anyone running this on a rev 2? Maybe 250 at the fly with this setup?
99ron
mr299ron wrote:Thought 15 psi would be the max.Why is this?
mr299ron wrote:So I could upgrade the injectors and fuel pump and be fine?
bobhatton wrote:mr299ron wrote:So I could upgrade the injectors and fuel pump and be fine?
No, you will need an ECU to control them and you still have 8.8 to 1 compression pistons in a Rev 1&2
The stock engines run under the control of the knock sensor most of the time so turning up the boost makes that worse.Head gasket will blow first, once that if fixed the piston will be the next to go.
If you want more power the correct way is to fit lower compression pistons then you can do what you want with boost pressure
mr299ron wrote:
So get off your high horse and stop being a mug
I think it was just advice..
parker455 wrote:I bought a rev2 to start with, moving onto a rev3.Learnt everything with it and it never let me down.
I've nothing against them as that's exactly what I did with my first mk2 turbo!
CalMac wrote:For the record I also have a Rev 1, so I wasn't just being an ar$e
