Rear number plate light
russgregg
Post by russgregg »
This may be a stupid question but do mk1's normally have 1 rear number plate light (below the plate) or two (one on each side)
the reason i ask is because i took off the rear plastic trim to do some respraying and it would seem that my '86 mk1 originally had 2 lights but one of the previous owners took them out, filled and sprayed over the holes and then cut a new hole under the plate and mounted an altogether new low light - why would you be bothered!!
Russ
kevin..in
Re: Rear number plate light
Post by kevin..in »
two one eitherside is standard
User avatar
Lauren
Post by Lauren »
Stock number plate lights:
