These will go on a Rev5 NA which will mostly see road use, and is not super low.
Can anyone comment on which would be the better quality?
I will refresh/refurb the rest of the suspension at the same time.
Your help making a decision is appreciated!
coanda
1988 JDM AW11 SC - In the middle of restoration and repaint.
1998 UK SW20 Rev.5 - A nice daily driver with some cool bits and pieces.
+1 on Meister R, nice on the road. 10 months over bumpy roads on mine and i dont have any complaints.
Also i have to say the comunication with the seller was excellent.
I've had HSDs on two different cars now (one set of DT's and one set of monopro) and can highly recommend them, Driftworks customer service is excellent too - I had my mono's supplied with different spring rates at no extra cost
short of spending lots more money on something like Ohlins, apexi N1 etc you can't beat them.
Apexi N1 are probably the worst coilover choice for a road car, felt like i'd fitted no suspension at all. jdm ohlins almost as bad, both the phoenix power ones and the soqui/ohlins ones.
Thanks all.
Seems fairly even then.
I didn't realise H&R do a set for the SW20. I shall check them out too - what's been your experience with them?
I have also had a good experience buying from Driftworks. I actually have a set of SW20 monopros half fitted to my AW11 - realising the mods required.
One thing I am hoping is that whatever I go for, they'll be a bit better on space than the TEIN Super streets that are currently on the car. The wider front wheels mean I need 8mm spacers so that the rims clear the suspension, this means I could also do with wider front wings so anything I can do to move the wheels back in will be a big saving. I don't know if the set-up is using the double camber adjuster trick to help out with this - something else to check out.
I also expect that the ride comfort will improve over the TEINS!
