I recently suspected that that my rear arches were looking a bit rusty so decided to spend an afternoon removing my rear bumper and I found
![Image](http://i304.photobucket.com/albums/nn194/angpozzuto/5823EA7E-465C-4C40-B065-423F2574DE88_zpsjveguzci.jpg)
![Image](http://i304.photobucket.com/albums/nn194/angpozzuto/B134788B-EAE1-4413-9829-AFC97D52252E_zpsqzbecqfe.jpg)
![Image](http://i304.photobucket.com/albums/nn194/angpozzuto/C76CF239-F927-414E-8591-DCDB422C2839_zpsvq21n7xh.jpg)
Rob - East Coast Imports wrote:I spy a clarke MIG welder in your garage) if you can be bothered.
Angpozzuto wrote:So do I need to keep them
masterbateson wrote:I had an xjs that looked mint!
Anyway for one reason or another I had to repair a piece of bodywork underside, radius arm mounting point.
So i began to cut and cut and cut and so it went on, as i didnt want to weld to anything bad.
I couldn't weld yet and had never done body/panel work, anyway bought a welder,watched vids on welding, got a old bonnet froma scrapper i go too(free from mr scrap
as it was all dented) and cut holes in it and practiced.
Anyway the moral of this story was sometimes what appear to be a good car sometimes isn't, especially when someone previous has tried to hide it.
The other thing is,eventually i got there,learnt a lot in the process and learnt some good skills.
It aint easy tho.
Dont rush it, if you tackle it your self.
P.s.
Start of cutting out,then you can make carboard templates out of anything, i used to raid all the households cereal boxes![]()
and if your trying to fabricate large difficult shaped area's
make them up out of several smaller pieces and tack them all together
, you can seam weld them later running lots of small tacks into each other.
That way if your a novice you wont burn thru the metal.
