Speedo and Odometer not working
RandyAndy
Post by RandyAndy »
1993 MK2 turbo jap import, been for a full service and asked them to look at speedo as it wasn't working, they said speedo was electronic and should ask you guys on the best thing to do. Anyone come across this before?
2mad
Re: Speedo and Odometer not working
Post by 2mad »
Mine did this .. bought a cheep gps speedo with speed camera alerts lol for £40 .. good investment .. sorry i cant help :cry:
Ps. on the plus side my mileage never went up :lol:
thomp1983
Post by thomp1983 »
Check the speedo sender in the gearbox would be a good place to start
2mad
Post by 2mad »
thomp1983 wrote:Check the speedo sender in the gearbox would be a good place to start
Thats what i did .. looked fine went gps 8-[
RandyAndy
Post by RandyAndy »
2mad wrote:Mine did this .. bought a cheep gps speedo with speed camera alerts lol for £40 .. good investment .. sorry i cant help :cry:
Would rather fix the speedo cause on the MOT it'd show as i've done no mileage, next owner would think the clocks had been turned back or something
thomp1983
Post by thomp1983 »
Check the sender is producing an output, this would require a scope, also check continuity from the sender to the clocks. After that check the clocks.
Also does your car have a speedo converter fitted? If so try removing it temporarily it also may have failed
2mad
Post by 2mad »
Yeah i used to wind the clock forward 500miles every year .. not the best option but that was my car life lol 8-[
mr2magic
Post by mr2magic »
In my experience it's either the nylon ring gear on the diff or the nylon gear on the speed sensor. Remove the sensor from the gearbox and take a look.
alanmr2turbo
Post by alanmr2turbo »
How do you get around it going into limp mode when ECU doesn't get a speed signal for 3secs?
alanmr2turbo
On getting it working.
Check purple wire from sender to clocks.
Check the sender still has the nylons wheel as they come off.
Check nylons toothed wheel in gear box, they tend to snap.
My speedo don't work as nylon toothed wheel in gearbox just spins freely :cry:
tsango
Post by tsango »
mr2magic wrote:In my experience it's either the nylon ring gear on the diff or the nylon gear on the speed sensor. Remove the sensor from the gearbox and take a look.
Yeah I had a non working speedo and it was the gear in the gearbox. Gearbox out job unfortunately.
2mad
Post by 2mad »
Never had this problem mate .. car ran sweet :thumleft:
Rev2 engine .. rev 1 car :thumleft:
thomp1983
Post by thomp1983 »
the car doesn't go into limp mode with no speed signal it just logs a code 42 which doesn't put the light on
2mad
Post by 2mad »
thomp1983 wrote:the car doesn't go into limp mode with no speed signal it just logs a code 42 which doesn't put the light on
Sorry bud had a ligtht come on from time to time .. no problem though :)
5 Years .. never cut performance .
Ginjaninja92
Post by Ginjaninja92 »
Yeah I've currently got a not working speedo and it's logging a code 42 but no limp mode, not even looked at it yet but I'm hoping its just the sender in the box.
mr2magic
Post by mr2magic »
I don't want to burst anyones bubble, but if you have a non functioning speedo and the cause is the ring gear on the diff then you're in deep doodoo!! This part ist one of thousands of discontinued parts (I have a large list of part numbers on the german board) that are not available new anywhere :-(
The small nylon gear on the sensor itself is still available though!
