Manual choke/air con idle vsv connector
mosguido
Post by mosguido »
Hey,
While back I posted about an issue and found that the wiring id
Not seen before in my engine bay was actual a manual choke modification. All good until driving the other day the revs bounced and on further investigation one of the cables from the connector to the aircon idle up vsv had broken and clearly causing this new problem. So am trying to fix it now and I actually need a new connector to plug into the aircon vsv thing but I can't for the life of me find anything similar new or secondhand online anywhere that looks like it would fit onto the connection.
Does anyone know what type of connector is required or where I can get one from? The actual vsv is fine just the plug/connector where the wires go to is broken..
Any thoughts, or is there even an unused plug in the engine bay I could reuse?
G
jimi
Re: Manual choke/air con idle vsv connector
Post by jimi »
If it's this type VSV that's been used then it's from a MK2 and there's nothing on a MK1 will fit it, best bet will be a breakers or someone breaking a MK2
