After rigging up all electrics and jumping it off of my Peugeot the engine cranks healthily but does not fire up.
Obviously I will check to see if I have a spark to start with, but is there anything else more obvious before I do this?
I have had the head off and apart and all corresponding sensors/connectors disconnected.
The compression test came out eventually at 160-170 across all four and there is no nasty banging noises when it's trying to start up.
Any ideas that smack you in the face?
