As Lauren says, it'll be fine.
I'm currently running a Mongoose
(Which is basically the same exhaust) on our SC conversion.
The only issue you will get fitting n/a exhaust parts to an SC is if you start changing the manifold
- The SC has an O2 sensor mounted in the manifold whereas a
(UK/European spec) n/a does not.
Even the manifolds are the same casting but the SC one has the mounting point for the sensor drilled out so it's something to be aware of if you try to fit an aftermarket tubular manifold to an SC
