Cambelt Tensioner
SuperRedMR2
Cambelt Tensioner
Post by SuperRedMR2 »
Hi,
I am having issues getting the cambelt around the tensioner.
Where is the best place to lever the tensioner to enable me to get the belt around it?
Every time I attempt to move it, it either comes off the little dowel on the block or the spring loses tension and comes off. Both very infuriating.
Please help
PW@Woodsport
Re: Cambelt Tensioner
Post by PW@Woodsport »
Leave the locking bolt/pointer just slack, use a pry bar and lever the pulley back to full extension, lock the bolt.
Fit the belt and unlock the bolt, then bounce the tensioner a few times from behind to take out any slack between the pulleys, lock the bolt and rotate the engine a few times, check alignment and unlock/lock the tensioner one more time.
That is my method and i've done more Mk1 belts than Toyota i bet!
SuperRedMR2
Oh yeah thanks Paul.
That would have been a much simpler idea!
