The time has come to sell my pride and joy.
Ive owed it since 2004.
The base car is a Rev 3 GTS T-Bar, however has since been extensively modified.
The spec list is massive, so i am likely to add to this as I remember.
The engine is built around a TTE block as used by the original GT4 3SGTE, which went on to win many a World Rally Championship.
The block is easily capable of 1200 BHP if required, without issue of cracked cylinder walls.
This engine has currently around 7000 miles on it, since being built in around 2007.
The first 2500 of which were the running in miles.
The total mileage of the chassis is just a shade under 80,000 kilometers.
The car revs to 9000 rpm without issue whilst still making power, thanks to 9:1 a CR
(unheard of on a turbocharged car back in 2007).
The car is mapped by Dave Rowe using probably one of stingiest dynos in the country, yet still made huge power.
I spent a lot of time with Dave Rowe both dyno mapping and road mapping to get it pretty much spot on.
The engine starts up first time, idles a bit rough from cold, but once warms up idles at 1000rpm and runs perfectly.
Though it isnt exactly road friendly at low revs, with an extremely sharp clutch and throttle response, it takes some getting used to.
But once mastered, it becomes second nature and a dream to drive.
This engine since being built hasnt missed a beat pull after pull on the Dyno and still drives home immaculately.
In its current state the car makes anything between 350 BHP to 720 BHP depending on boost, which is adjustable via a Motec Rotary Switch.
Engine Specification:
2.1 Long Rod Engine Built by Jems Race Engineering
Customised TTE Block
TTE Crank
Custom Pauter Rods
ARP 625 Bolt Upgrade
Custom CP Pistons
Ferrera 1mm Oversize Valves
+ Extensive Headwork
ARP Head Studs
HKS 272 High-Lift Camshafts
TTE
Inconel Exhaust Manifold with custom adaptor plate
Custom ported GT35R Turbo
+ Anti-Surge Housing
Tial 44mm External Wastegate
2 x Turbosmart BOV
Custom Rear Oil Cooler Kit
Custom Hayward
& Scott Exhaust
Jems Racing Custom downpipe
+ Screamer Pipe
Custom BMC Air Intake
OEM Intake Manifold
75mm BBS Throttle Body with custom springs
Jems Racing Custom Breather Setup
Jems Racing Custom Header Tank
Aquamist 2C Kit
Jems Custom Baffled Water Injection Tank
Custom Water/Oil lines all Earl braided
Cooling:
Concept Racing Chargecooler
Bosch Chargecooler Pump
High Pressure Water Lines
Samco Water Hoses
Jems Engine Radiator
Jems Chargecooler Radiator
ECU:
Motec M4
+ Advanced Features
Motec Adjustable Rotary Switch
Transmission:
OEM Shot-Peened Rebuilt Gearbox
Fensport Triple Plate Clutch
(brand new clutch plates)
Kaaz 1.5 Way Differential with medium rebound on the plates
Kaaz short final drive
Suspension:
BC Racing Coilovers
HT Front
& Rear Anti Roll bars
Polyutherance Bushes All Around
Uprated Drop Links
Custom Front and Rear Engine Braces
Custom Engine
/ Gearbox Brace
TRD Top Mounts
TRD Engine Mounts
Cusco Front Strut Brace
Ultra Rear Strut Brace
Brakes:
Cross-Drilled
& Grooved Brake Disks
Carbotech XP-10 Pads
Goodridge Hoses
Fuel System:
Customised Bosch 044 Racing In-tank Pump
Aeromotive A1000 External Pump
Aeromotive Fuel Filters
Custom Swirl Pot
Wolfkatz Fuel Rail
Bosch 1000cc Injectors
Custom Earls lines
(recently refreshed)
Wheels
/ Tyres:
16 Staggered Rays Setup
Toyo R888 Tyres
1000 miles old
lots of tread
Bodywork:
The bodywork is in excellent condition, considering the car is 20 years old.
Currently a few minor scratches and door dings here and there, however, nothing major.
Toms Side Skirts
Toms Rear Bumper
Greddy Lip
Ganador Wing Mirrors
Interior:
Custom boost gauge in instrument cluster
SPA Intercooler IN/OUT gauge
+ sensors
Aquamist DDS3 flow gauge
+ sensors
Greddy Gearknob
Sparco F1 Race steering wheel with Momo hub
Electronics:
Full Racelogic Traction Control
Custom Wiring All Heatshrinked
Brand new slim line Bosch Battery
As has been said, the car needs nothing done to it.
It has just had a fresh MOT.
The car is religiously serviced between 2000-3000 miles without fail, only using Millers Oils.
The car currently has no speakers nor stereo, however if i meet the asking price or very close to it, i can arrange to have something basic installed.
However, if youd prefer a roll cage fitted, i can arrange this with Patrick
@ Rogue Systems, only if i meet my asking price.
The car has run 10.6 in its current state back in 2010 and is easily a 9 second car if more time can be spent on stripping it out, making it a dedicated drag car.
On the other hand and in my personal opinion, this car will make for an excellent race track car to enter the MR2 series championships or a Time Attack series.
The car has been with Patrick
@ Rogue for the best part of 18 months and I have just spent
(June, 2015) over
£3000 with Rogue for a full fuel system refresh replacing most of the lines, clutch refresh and loads of other odds and sods.
Any viewing welcome, i am based in Coventry, or I would be happy to meet at Rogues place if that is more convenient.
You'd be hard pushed to find a more complete MR2 then this.
Considering it has a potential 700BHP+ on tap it has total road manners, yet TOTAL BRUTALITY when pushed.
To give you an example we made a round trip of over 300 miles to a 30MPH-130MPH Mitsubishi Evo day, came 7th on the day and 3rd in the top speed run
(was still pulling at over 180MPH but ran out of road).
This car never missed a beat.
For those that havent seen the youtube video of it on the dyno, take a look and listen to this
(put the speakers up, though sounds better in person):
http://www.youtube.com/watch?v=i1ZMOWjWYFM
Project Thread Here
(sorry didnt keep it up to date)
http://www.imoc.co.uk/forums/viewtopic.php?t=37264
Project Complete Thread Here:
http://www.imoc.co.uk/forums/viewtopic.php?t=125257
Test drives will be carried out by myself ONLY.
No cowboys, tyre kickers or jokers.
This is a serious piece of kit, which can go horribly wrong in the wrong pair of hands.
A friend of mine runs an export business, so getting a container and delivering abroad is an option, if need be.
£15,995 ONO
(May take something up to
£6,000 if i like it.
Must have 4 seats.
[email protected]
