Finished IMOC footage from Elvington
BenF
Premium Member
Post by BenF »
Folks,
OK, its done. The clip is about 3 minutes 40s and includes footage from the paddock of cars there, and cars/entering leaving the circuit (Ta Dale), in/on car footage from my setup on the Roadster, and still photos from cars on the track and in the paddock.
Thanks to Michael Canny and Mark Nias for allowing me to use their photos.
When creating the files, feedback was that most people were on broadband and weren't too worried about filesize so I've produced two very high quality versions which are 38MB in size - one with music, one without, and one at VHS quality which is half that size.
High resolution clips with music:
http://www.imoc.co.uk/users/BenF/Elving ... _music.wmv
High Resolution clip without music (its the same size)
VHS quality clip For those on dialup or slower connections -14MB:
NB - If you have a dialup connection, it will take ~90 minutes to download the VHS quality link.
If you don't have a fast net connection, I can burn these to a CD and put it in the post to you in the UK if you buy a IMOC Sticker Pack at the same time :D - see the General section for more info.
MartG
Re: Finished IMOC footage from Elvington
Post by MartG »
1min 27s - peak rate of 3.2Mbps ( downloaded it at work :D )
Excellent video ! =D> ( and the first still at the beginning was a good choice :lol: )
Rikki
Post by Rikki »
Brilliant stuff!
Loving the Mk3, I've tried the ar$e out thing in my mk2 tubby and usually ended up facing the wrong way :D
R.
phild
Post by phild »
excellent video, even in the lower quality mode.
Could do with an hour of it !!!! :D
Perhaps you could put everything you took on a dvd and flog it on here?
surferdude
Post by surferdude »
Nice clip dude! =D> =D>
BenF
Premium Member
Post by BenF »
MartG wrote:1min 27s - peak rate of 3.2Mbps ( downloaded it at work :D )
Ta! You've got a nice fast link for that then :)
Yours was a very nice 'clean' Mk1 hence the early feature in the video. I tried to get a balance of Mk1 / Mk2 / Mk3s in the footage - there were fairly even numbers of each type on the track.
When I 'tested' downloading it from home (2Meg Cable) it was coming in at 50k a second - took a few minutes to arrive.
BenF
Premium Member
Post by BenF »
Rikki wrote:Brilliant stuff!
R.
You just need more practice ;)
It is possible to powerslide the Mk2 around, and having a mk2 with a Limited slip diff makes it even easier - some Mk2 Turbos would have had one fitted as a factory option.
If you don't have a LSD you can get the back end out (eg Lauren's Red Mk1 in the pics ) but you have to provoke it by lifting off and turning in sharply, early.
My 2003 Roadster on 2001 alloys (tyres are narrower on the rear) is great fun and very nicely balanced - you can make it oversteer by using power mid-bend (or spin if you lift off!) or you can provoke it like I do part way through that clip - early, sharp turn in with a lift and then back on the power - but I made a dogs dinner of recovering it :clown: and I carred a little too much speed into the next corners - or it was the rear tyres massively overheated losing grip.
Huge fun though :D But the tyres were down to the cord by the end of the day - there was ~ 3mm of tread there at the beginning of the day, but I didn't mind as I had another set of part-worn tyres to go on 8)
BenF
Premium Member
Post by BenF »
phild wrote:excellent video, even in the lower quality mode.
I've got loads of footage - the stuff that went onto that clip was just a few random extracts of stuff that looked interesting/good. I'll be putting up more clips (eg one lap, goonage, clips of other cars from the camera) next weekend.
michael
Post by michael »
Coming down at a healthy 230kb/sec here - I'm getting excited :)
Ekona
Post by Ekona »
Ben, that's abolutely awesome stuff! Great editing, and some really good footage too.
aaronjb
Post by aaronjb »
*points at screen*
Woo, there I go!
:) Yay, footage of me.. admittedly on a dull bit of the track, and not doing anything spectacular, but.. yay :)
Ekona
Post by Ekona »
I thought that was you: You were going so slowly, I thought my PC was experiencing severe slowdown for a second... :wink:
aaronjb
Post by aaronjb »
ekona wrote:I thought that was you: You were going so slowly, I thought my PC was experiencing severe slowdown for a second... :wink:
Bah, hush you :P My hand still hurts, you know! Damn your car :P
BenF
Premium Member
Post by BenF »
Heh, there were three Lagoon Blue Roadsters that I saw - I've got some footage of us all together at some point :)
aaronjb
Post by aaronjb »
BenF wrote:Heh, there were three Lagoon Blue Roadsters that I saw - I've got some footage of us all together at some point :)
Yup - there was you with the hardtop on, me with the roof down and chrome TTE style bar, and there was at least one other which always had the soft top up.. :)
Goto10
Post by Goto10 »
BenF wrote:Folks,
Damn that 'keys' photo! :)
MartG
Post by MartG »
Just watched it again, and spotted that it's me accelerating away from the pits in front of you - I didn't realise how much smoke my car chucks out under boost, but at least its black ( ie. overfuelling ) rather than blue ( oil ).
Once again, excellent video =D>
BenF
Premium Member
Post by BenF »
Goto10 wrote:
BenF wrote:Folks,
Well, I wasn't going to say anything unless ... ;)
Speedy
Post by Speedy »
MartG wrote:Just watched it again, and spotted that it's me accelerating away from the pits in front of you - I didn't realise how much smoke my car chucks out under boost, but at least its black ( ie. overfuelling ) rather than blue ( oil ).
I think it might be our SC - it does that at the moment.
Top Vid btw, will have to get a camera sorted out at some point!
anna
Post by anna »
Yup - from the wonky 'stinger' aerial, to the exhaust cowling falling off underneath, i'm pretty sure that is mine and Speedy's sooty SC...
