[Mk2] [Turbo] 35/52 error codes
bigdave247
Post by bigdave247 »
Hi guys, i had the engine warning light come on yesterday, i used the diagnosis port to get the codes 35 and 52 after looking them up i found that they refer to turbo pressure and the knock sensor.
Can anyone give me any advise on weather it is safe to drive the car with these problems ?
raptor95GTS
Re: [Mk2] [Turbo] 35/52 error codes
Post by raptor95GTS »
I think that means the car has overboosted, hit fuel cut and popped the Knock Sensor into the bargain. Did this all happen after you had had your foot down, ie boosting hard?
bobhatton
Post by bobhatton »
If the knock sensor has gone the engine will only run in get you home mode.
I would not use it for long like that.
Replace the knock sensor with a new Toyota one and try and find out why the engine has so much knock that it damaged the sensor.
bigdave247
Yea light came on after using full boost in 2nd, also i have got my
turbo turned upto 15psi .
Al-sw20
Post by Al-sw20 »
Code 35 is the sensor, code 34 is overboost.
52 means you need a new knock sensor. Make sure you use genuine Toyota.
bigdave247
Nice one cheers ill order those parts
2mad
Post by 2mad »
bigdave247 wrote:Yea light came on after using full boost in 2nd, also i have got my
14/15 psi tops is ok just disconnect you map sensor if you dont have a fcd ... popping your knock sensor is really bad .. not an easy thing to do .. maybe take things easy till you find out why .
