Peter Gidden - SBITS wrote:You have a short circuit.
Unplug cigarette lighter and try a new fuse.![]()
Does fuse blow?
magic_alex wrote:Peter Gidden - SBITS wrote:You have a short circuit.
Does fuse blow?
Yep after three fuses I gave up and taped the connector back up as I was short on time but I really need to sort this out, just havent got a clue where to start.I realise that the radio and dome light are also on same fuse but have no issues with them.
Peter Gidden - SBITS wrote:If the fuse only blows when the cigarette lighter is plugged into the loom, then the short circuit is obviously in the cigarette lighter itself.
magic_alex wrote:Peter Gidden - SBITS wrote:If the fuse only blows when the cigarette lighter is plugged into the loom, then the short circuit is obviously in the cigarette lighter itself.
Ok is this something I can fix or should I just find a replacement part? Like i say I know nothing about electrics![]()
Peter Gidden - SBITS wrote:magic_alex wrote:Peter Gidden - SBITS wrote:If the fuse only blows when the cigarette lighter is plugged into the loom, then the short circuit is obviously in the cigarette lighter itself.
Get a replacement.
Try posting in Items Wanted forum.
