After about 30 mins noticed the battery light, cat light and intercooler fan light has all come on, voltage meter on turbo timer was reading low at 11.5 volts.
Turned everything on heater lights register etc voltage dropped 11.1 but then levelled out
Haven't got my multimeter with me, so used a battery/alternator tester.
Should all these 3 wires rear the same voltage?
Would this be the alternator has gone? Battery doesn't seem to lose any more than 11 volts even with everything on.
Has a wire broken/ damages, causing the lower voltage on one of the pins?
Info and help much appreciated
Thanks jamie
