Missfire and hesitation mk2 sw20 2.0 gt n/a
Atmu999
Post by Atmu999 »
Hi all... I have a mr2 mk2 2.0 gt sw20 n/a... Slight missfire on idle and hesitation when setting off... Replaced plugs, leads, dizzy and rotor, coil lol fault still there... The car had been sat for years in my garage... Anyone have any ideas please, much appreciated
fred130111
Re: Missfire and hesitation mk2 sw20 2.0 gt n/a
Post by fred130111 »
Have you used the built in diagnostics port to check for fault codes?
Atmu999
Post by Atmu999 »
Am gonna try get one soon... I don't have the connection yet... Will post results when done. Thanks for reply 👍
mr2magic
Post by mr2magic »
? What connection?
you just need to short Pins Te1 and E1 and then switch on the ignition. The CEL will then blick any codes stored.
Have you changed the fuel filter? Check the injectors aren't clogged.
Atmu999
Post by Atmu999 »
I was gonna get a scanner from a friend to check codes... I'll do that way and see what I get... New filters been done, I got a injector max machine at work which should hopefully clean injectors so I'll try that aswell 👍 thanks all
ashley
Post by ashley »
You don't use a fault code scanner on these cars- as said above: bridge the two connectors and read the fault code from the check engine light :thumleft:
Atmu999
Post by Atmu999 »
My bad lol... 4-1 so indicates throttle sensor... I'll clean it up and check earth. Anyone had this problem.. Years ago it was running fine the old girl lol. Might even treat her to a new one
Atmu999
Post by Atmu999 »
I've removed the sensor to check for dirt etc... Looks fine, then did a resistance check between pin vta and e2 it was 3.4 but as I twisted the throttle round the resistance moved up then 1/3 of a turn and went to open circuit... Am guessing it's the problem?
www.mr2oc.co.uk/know-your-2-knowledge-b ... kbartid=59
That's how I was checking
Thanks guys
wenguin
Post by wenguin »
May not help you directly, but if you're going to clean up the throttle body I found this chap's guide on AE86 TB refurb to be interesting - I think some of the logic to it applies to 3sge TB/sensor cleaning and ISCV config:
https://www.youtube.com/watch?v=_JD9BtoScL8
