Yesterday I had my throttle body off to give it a quick clean and put a new gasket on.
I disconnected everything from it expect the larger hose on the right hand side
(if you're looking into the butterfly hole).
I disconnected the hose at the bottom
(the thin one) and a load of liquid spurted out
- it sort of smelt like petrol
- is it petrol, or coolant?
Anyway, my problem:
- This morning I drove the car and noticed that when I revved the car, there was a loud water/slushing sound
- it sounded like it was coming from under the dash passenger side, or underneath the car.
- I got to where I was going and tried revving again and it was still there
- 5 minutes later I came out, started it up and tried again
- no slushing
- By the time I got home I tried again, no slushing
So it appears to only happen from cold.
Any ideas what it is? Was the hose on the bottom a coolant hose, and when some spurted out it has created an air gap? Or will it just need topped up?
Let me know if you need more details!
Thanks!
