[Mk2] [NA] Side Air Intake Trims Removal
How do you remove the engine bay side vents?
87 T-Bar Manual Supercharger
98 T-Bar Rev5 Sonic Shadow
Re: [Mk2] [NA] Side Air Intake Trims Removal
http://www.imoc.co.uk/forums/kb.php?mode=article&k=112
Unfortunately the images were hosted on ImageShack, and aren't showing.
I do seem to remember telling the admins at the time that the images for guides should be hosted themselves
Here this will help http://www.mr2oc.co.uk/know-your-2-know ... bartid=204
RyanRs wrote:Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously, you don't know the answer to this? and you call yourself a car mechanic
madbasshunter wrote:Here this will help http://www.mr2oc.co.uk/know-your-2-know ... bartid=204
Thank you, I was about to dig that one up, as mr2oc, despite their faults, they did host my images themselves
