coilovers
robbie_742003
coilovers
Post by robbie_742003 »
Hi all, my car has developed a knocking from the rear passenger and seems to be getting worse (or could be paranoid). My very friendly local mr2 specialist tells me I've got cusco coilovers and I've had a good look over all the suspension and the only thing I can see which is suspect is the centre nut isn't that tight on the stud. I've tried to tighten it but if just turns with the strut.
Is there anything i can do, my knowledge is very limited with these.
Rob
Forgot to mention, the centre nut is only hanging onto the stud by a few threads, danger? :-(
thomp1983
Re: coilovers
Post by thomp1983 »
Im guessing by centre stud you mean the centre of the strut that passes through the top mount? of so there's not usually much thread sticking out past the nut but the nut should be tight
Tsia
Re: coilovers
Post by Tsia »
Have you checked your rear drop links at all?
Draven
Re: coilovers
Post by Draven »
Top mount.. or drop links.
robbie_742003
Re: coilovers
thomp1983 wrote:Im guessing by centre stud you mean the centre of the strut that passes through the top mount? of so there's not usually much thread sticking out past the nut but the nut should be tight
Yeah the centre of the strut, there is no thread proud of the nut, the nut is only a few threads on the strut.
robbie_742003
Re: coilovers
Yeah I've checked the drop links and can't feel any excess play, they feel pretty tight.
What's the procedure for changing the top mounts, is it reasonably easy to do?
Thanks for the replies guys :thumleft:
Race Idiot
Re: coilovers
Post by Race Idiot »
Well if youve got coilovers the topmounts usualy have a spherical bearing which will have excess play. You'd have to remove the whole unit from the car and check.
Harrodbear86
Re: coilovers
Post by Harrodbear86 »
Second that
SonicSW20
Re: coilovers
Post by SonicSW20 »
Ball joints make a hell of a racket over bumps when they go.
Torero
Re: coilovers
Post by Torero »
Gazza_DJ wrote:Ball joints make a hell of a racket over bumps when they go.
+1 :thumleft: I changed to BC coilovers and Whiteline arbs but did the droplinks to try and refresh as much of the suspension as I could. Unfortunaely the car would still 'bottom out' (metal to metal) if I went over a pothole on the n/s wheel.
The moment I changed the ball joints it stopped, well worth it for £50ish all round but a beatch to get the old ones off.
3VZ-FE V6 TRD Widebody Replica
Draven wrote "TRD dude. TRD... Can see awesomness from anywhere. "
