We're trying to get the petrol tank out to replace the fuel pump and fix the fuel guage as we already have the engine out. One of the lines is proviong difficult as we can't seperate it. I've attached a couple of pictures of the junction that is proving difficult. You can see that the smaller nut head is starting to round off. I don't want to keep going and muck it up completely. Any ideas on how to seperat the lines? I've looked at pulling off the rubber hose just before the junction but it seems to have an inner hose connected to the larger nut head.
[/URL]
[/img]
The line in question is the one that travels along the chassis member before going up to the right.
Petrol tank removal
Re: Petrol tank removal
that line connects to the bottom of the fuel filter.
remove the line from the bottom of the fuel filter, it's also attached to the bulkhead by two small brackets.. you can then (carefully!!) manipulate it out in one piece.
or.. just cut it and then replace it, bearing in mind that that is the pressure side so you'l need to replace the whole thing, i.e the pump carrier and its attached line plus the line from the union to the fuel filter.
Line separation
Molegrips for more purchase?
Re: Line separation
cosmos wrote:Molegrips for more rounding?
Fixed that for ya
As Rob says disconnect from the fuel filter and try to take it out as one. I recently had the same problem but luckily I was replacing the whole fuel pump assembly as I had a spare so could just cut the rigid line.
Blue Lexus RCF
Black MKIV UK Manual Supra
Green MK2 MR2 Tin Top
Funnily i took my tank out yesterday, as has been said unbolt it from the filter and bulkhead and it will come out with the tank
Thanks chaps, hadn't thought about disconnecting at the fuel filter
