What's causing this? And is there an easy fix?
Ta Karl
mr2mk1chick wrote:sounds exactly like my prob.![]()
have done a temporary fix by turning up the idle screw when the car was hot and with revvs falling.
but i think my prob is having missing air sensors since K&N filter fitted without addign the sensors back in.
will let u know on that one.
check your sensors as this will give the ecu wrong info therefore the car could over fuel to compensate hence flooding and low revvs.
.maybe
another reason for a missing/ dropping idle thingy is having air in your coolant.
need to flush out.
either way i'm not v mechanical, but hopefully will give you a couple of ideas.
Limeymk1 wrote:That's one of these yeah?
http://www.fensport.co.uk/partsfiles/aw ... rmr2-1.jpg
I still reckon you're going to have issues with too much hot air.
Limeymk1 wrote:I have a feeling it is related to the cone air filters in the engine bay, as the heat in the bay increases the charge density decreases to a level which causes the engine to stall.Just a theory, I dont know if Mk1s with the original plumbing suffer from it.
