Front Koni inserts mk1
mark35
Post by mark35 »
Have been trying to fit my front Koni inserts for my mk1 but can't seem to get them to sit right to the bottom of the casing.
Any ideas
mark35
Koni
Post by mark35 »
Can't believe no one has had this problem before.
PW@Woodsport
Re: Front Koni inserts mk1
Post by PW@Woodsport »
I've installed literally hundreds of sets of Koni inserts and never once had the problem you are having..... therefore one must conclude you are doing something wrong or your shock tubes are bent maybe, either way the problem appears to be unique to your car.
mark35
Koni
Post by mark35 »
Have measured the inserts and they are 6mm to long for the casing.
Have checked the part numbers for the inserts and are correct.
The casings are toyota ones not after market replacements.
Have now filed the bottoms of the shocks by 6mm. There was a sort of nipple on the bottom so have removed a bit of this to make them fit. Now the large flange nut now does up tight with a 4mm gap between the casing and nut.
PW@Woodsport
Never had to make Koni inserts fit in 15 years of fitting them.
Something definitely not right.
Polypedates
Post by Polypedates »
My first set of rear KYB inserts didn't fit; they were too long for the strut casings and too narrow. I assumed I was given Mk1A items instead of the Mk1B inserts I needed.
On explaining the problem to the supplier and my theory as to why they didn't fit they sent me replacements that that did. I had no problem with the fronts though.
mark35
Koni
Post by mark35 »
The rear ones fitted fine it's just the fronts which I am having problems with.
It must be my strut casings then.
