Electronic speedo clusters
(Rev2+)
I'm not an expert on this, but from what I've read whilst trying to sort out my own cars this is what I learnt.
Putting aside the fact that the NA cluster has a voltmeter and the Turbo in theory has a working boost gauge
(not that mine has ever moved), you can not just swap one cluster for the other.
Apart from anything else, the layout of the warning lights is different on the NA compared to the Turbo, so there are likely to be associated wiring issues.
The turbo cluster is also fitted with an extra circuit board to operate the boost gauge.
But as far as I'm aware the gauges themselves are directly interchangeable, apart from the boost and voltmeter gauges.
When it comes to converting a JDM speedo in kph to mph I believe there are a number of options.
The most common are:
Fit a new mph speedo face that had been designed to give the
"correct" readout in mph for any given position of the needle without any need for an electronic converter.
With this option the power steering will continue to function as intended for the JDM market, but the odometer will continue to read in kph.
Replace the actual speedo gauge with one from a UK car.
This automatically uses the standard pulses received to display the speed in mph, and the odometer will log the miles driven.
With this option you don't need to fit an after market kph to mph converter, and the power steering will continue to function normally.
But unfortunately the limiter circuit will be triggered by the UK speedo.
To get around this you can fit a delimiter at the input to the ecu.
Clamp a Steph delimiter across the four terminals on a JDM speedo.
This will convert the pulses received so the gauge reads mph, whilst maintaining the correct signal to the power steering to allow it to operate normally.
These are only available second hand, and you need to be quick to grab one when they come up.
Finally you can fit the basic style of electronic converter to a JDM speedo which will allow the gauge to display your speed in mph, but the downside is that when fitted in the speedo cluster they adjust the pulses and confuse the power steering.
For my own part, on my NA I simply went for a dial face change using Lockwood white dials, but they do tend to over read.
I've also lived to regret the change to backlit white faces, especially around dusk.
I now have a turbo which is again fitted with white dials and some sort of converter.
Until I take the cluster out I don't know what type.
But my plan is to assemble a replacement Turbo cluster using Speedhut dials taken from an NA cluster, and fit a Steph Delimiter to sort everything out.
I'll also be replacing the turbo boost gauge with an NA voltmeter which will involve a couple of minor changes to the wiring of the additional boost gauge circuit board, but I will at least end up with a useful gauge.
Hope that helps clarify things a bit.
Paul
