I think this is the right board and using the search failed to give me any meaningful answers so.
My car's
(Rev.
2 turbo import) front suspension has had it
(And the back springs are not too good either).
The shocks were leaking a while ago and now I am looking to replace all of it, as in upgrade, but I am not sure to what.
However I don't want to harden the ride much more as I think the handling is pretty good as is.
I would just be looking for a bit more responsiveness.
The question becomes what should I get?
Do I get coil-overs, and the inverted shocks is an appealing idea, but what is the advantage of coil-overs when rated against the yellow Bilstein shocks? Bearing in mind I would not be looking for spring rates or dampening rates much different to stock.
Which also leaves me with the question what are the stock rates?
Lastly I was tempted to go with stock replacements but the Yellow Bilsteins seem to be cheaper though I am willing to fork out a bit of money for quality.
Anyone's opinion/experiences would be greatly welcomed.
Paul.
