It sounds like it's revving higher then it should at the start of a journey.
Only had the MR2 a couple of weeks so not sure if this is normal or not.
Jam wrote:
I've taken the idle speed control valve, the sensor and the throttle body off and given them all a good clean, but it's made no difference.
Fozzy wrote:You could try the temperature sender.If this is faulty it doesn't know when to apply or shut off the choke settings.
I believe this is the green bodied sensor fitter to the coolant outlet of the head, just above the gearbox.
I think it was about 30 from Mr T, it cured my idle issues
QUOC2008 wrote:Check the throttle cable it might have got stuck on somethimg or sticky
bobhatton wrote:
If you removed the TPS it must be set up as per the BGB or it may not set the ECU into closed loop for idle.
The AC idle up valve is also a place to look as they often stay open.
