As I am now able do drive 1.5 bar over 5000rpm my fuelpressure begins to drop and the limp mode of my ecu was activated.
fuelpressure 4,8bar at 5000rpm drooped to 4.5bar at 6000rpm.
I have a supra fuel pump and 870 top feed injectors with the correct top feed rail from wolfkatz.
The fuel lines from the fuel pump and the fuel filter are still standard.
I thought the supra pump and the original fuel lines incl filter should be able to easily support 500bhp, or am I wrong?
