When I plug the antenna into the back of the head unit will this also provide power to the antenna or do I need to provide a separate power feed?
Cheers in advance
RyanRs wrote:Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously, you don't know the answer to this? and you call yourself a car mechanic
madbasshunter wrote:You need a seperate power feed which you will find on the back of the sony either a blue or blue and white wire![]()
madbasshunter wrote:I answered assuming you have gone for the windscreen aerial with built in booster http://www.halfords.com/sat-nav-audio/c ... mb-dab-aa1
