Identifying CT26 turbine wheels
Here's the only half decent info I could find online.
Inconel/Metallic wheel on the left, Ceramic Wheel on the right
![Image](https://home.comcast.net/~djdelong/Pictures/CT%20Turbo/CT%20exhaust%20wheels.jpg)
So according to this info you can identify the wheel type by the shape of the nut,
Info is from here:
http://www.mr2oc.com/showthread.php?t=282510&pp=30
This info ties up nicely with the three turbo's I have at home.
Turbo number one is a totally standard CT26 from JDM Rev2 MR2 Turbo so should have ceramic wheel:
![Image](http://i292.photobucket.com/albums/mm18/Danbob101/IMG_20140908_194313_zpsnvtedfds.jpg)
You can see it has the six sided nut
Second up a Turbo Technics rebuilt CT26,
![Image](http://i292.photobucket.com/albums/mm18/Danbob101/IMG_20140908_194433_zpsepm1tjog.jpg)
12 point nut,
Finally my Hybrid CT26, which is the one I actually care about:
![Image](http://i292.photobucket.com/albums/mm18/Danbob101/IMG_20140908_194519_zpsahzgoi4e.jpg)
This one also has the 12 point nut,
So can anybody confirm definitively how to identify the
Can anyone confirm if ceramic turbine usually has 11 fins and metallic has 10 fins?
From what I've found, neither will be magnetic so can't use that to test.
I did try using the search feature to find this,
Dan
