new mr2 owner
mr2paul
new mr2 owner
Post by mr2paul »
Hi
Loved these cars for years and finally got one.
Pictures to follow, but it's a 96 t bar.
First of I'm sure will be many questions is, I was told it was a sonic shadow model but my insurance company said it was a 10 year anniversary model....are these the same or how can I tell which it is?
Ben
Re: new mr2 owner
Post by Ben »
Sonic shadow is silver paintwork with a black roof :)
Welcome, btw! :thumleft:
2001 BMW M5 (Bahnstormer) | 2004 RX8 231 (the Racecat) | 2001 Volvo V70 (Swedish eBay barge)
Previous:
1989 MR2 Mk1b T-bar | 1988 MR2 SC Super Edition
MR2 Turbo Boy
Re: new mr2 owner
Post by MR2 Turbo Boy »
Welcome to the mad house, bud.... :thumleft:
mr2paul
Re: new mr2 owner
Post by mr2paul »
Yep
That's what it is, silver and black roof.
Bit of an eBay gamble.
Drives well but looks unloved, already found hole in rear valence corner
Anything I should look out for...
How easy is a cam belt to do?
mr2paul
Re: new mr2 owner
Post by mr2paul »
Yep
Re: new mr2 owner
Welcome buddy. :thumleft:
Unfortunately, as these cars get older, they are starting to show the number one weak spot. This is the sills, primarily the rear sill section.
Here's pics of mine before having a new section welded in, and after:
before:
after:
Many others have had to have similar work done. :(
ads
Re: new mr2 owner
Post by ads »
Welcome to imoc
First job you need to do is check the rear sill area starting from the inside - remove the rear side interior panels situated behind the seats ( where the rear speakers sit )
You'll find a piece of foam stuffed into the rear corner of the sill . Fiddle to do, but pull it out from both sills and bin it. This is because the foam collects water and causes it to rot from inside out.
Then it's time to check the outer sills .
Apart from this area of the sills these cars are not too bad corrosion wise. Nip any rust in the bud right away and you'll be fine.
Have fun with your new toy :thumleft:
mr2paul
Re: new mr2 owner
Post by mr2paul »
I'll have s look..
But harder than my 4X4's for access..lol
