I have a rev3 turbo and need to fit an oil pressure and temperature gauges.
What is the best way to do this? Is there room for a sandwich plate and sender units? If i recall the filter is quite low and would prefer not to lower it further.
The other idea i had was to run a braided line from the block and mount the sender units in the engine bay.
I'm curious to know what others have done
