The garage that removed my coilovers for me, also removed the front 2 EDFC motors but for some reason left the rear 2 still attached.
Any help will be much appreciated.
Ren0W wrote:Have removed mine 2 weeks ago.
https://www.flickr.com/photos/63058093@ ... 374714605/
Also unbolted with 1 set still attached.Don't know if they are also the rear set.
If so, it's because 1 set could be removed from the car with the EDFC still attached and the other one not.
Anyhow: just use 2 water pump plier or some adjustable spanners and place 1 around something of the coilover that keeps turning(the groovy disc is what I just to clamp) and 1 on the EDFC rotor
(gently).
And just turn.
