Hi all,
How do i check\replace the gear box on on my AW11 mk1b mr2?
Any other fluids that should be changed other than oil, break fluid and coolant?
When should this be done?
Cheers all
2.6litres http://kniah.wordpress.com/2012/05/06/m ... commended/
You should definitely do the coolant and brake fluid if you haven't done them before. Coolant system is about 12litres. Should be able to do the brake fluid with 1 litre.
+1 for Redline MT90
Just make sure you can undo the filler nut on top of the gearbox before you drain the existing oil out of the bottom as stated in the write-up!
