kev8611 wrote:Surely a small turbo with high boost will generate higher charge temperatures than a big turbo with small boost.
In turn the big turbo with small boost will help reliability.also for 350bhp I dont think its necessary to run low comp.
Definitely go forged but pretty sure you can stick with standard cr ratio
Adam W wrote:Wossner list two different part numbers for 8.0:1 pistons for the 3sgte.9055 which has a different combustion chamber volume to 9036.
The 9055 piston has a deeper dish, so I don't see how they can both have the same comp ratio? Any expert advice much appreciated!
(I am trying to build the most reliable 350bhp engine I can for track use, aiming for a small turbo with high boost to make decent power with good throttle response.
