Hi all
This only happens on a cold startup.
I get a high speed motor type whining noise for a few seconds when I startup
then it disappears.
There is no such noise during driving or when shutting down.
Likewise, once the engine is warm and restarted the noise is not present
- it really is just the one time on first cold startup.
The alternator belt is fine and I've checked the tension.
Could it be the starter motor spinning on but then if it is then why only on cold starting.
Likewise if its alternator then surely it would present at every startup regardless of whether the engine is cold or warm.
Any ideas please.
