Hi
I'm having a real problem with my speedo.
I've changed the speedo, the sender, changed the ground, and rewired the signal wire, and still can't get it to work properly.
The problem is it works intermittently and over or under reads when working, then after a few miles it stops completely, leaving the car for a while and the gauge will start working as before.
I've also removed the delimiter, and that makes no difference.
I'm running out of ideas so im thinking about the idea of changing the whole lot with an after market set up, not sure if it's possible?
The one concern i have is the power steering
Scott
