My cars partially poly bushed, but apart from that suspension wise it's standard
Donato wrote:Drop links are a must! They come with shortened front droplinks, so you'll only need new rear ones.They are pretty much impossible to take off if they haven't been done in a while.
If you want to preserve your coilovers, you might want to purchase socks for them;
https://www.tegiwaimports.com/index.php ... 300mm.html
The lower you make the ride height, the worse the car handles.So a good set of Roll Centre Adjusters will balance that out.
coanda wrote:So I think what Donato is saying, is that the RCA resets the angle of the lower arms to the value at the original ride height, after you have lowered the car?
juliankv73 wrote:
Pictures speak a hundred words lol
Thanks I get the principle now![]()
JD wrote:You can get the Tanabe 30mm+ ones for about the same as white lines.![]()
I'm eyeing up a set on fleabay but would have to import from americaland.
