At idle or less than 2k rpm its very very low but does rise as you accelerate.
I didn't change the pump during the rebuild as I never had issues before hand with it.
I changed the sump on this engine from the corolla sump to mr2 sump as it had the outlet hole for the oil cooler.
Faulty pressure sender?
I must also at that when the engine is cold, on the gauge it's halfway but when its hot at idle i've got hardly anything at all
