Im offering out a basic split rim refresh and rebuild!
For
2 or 3 piece wheels fully stripped down
Rim bolts cleaned and removed of corrosion
Nuts also cleaned off of excess corrosion
Center pieces powder coated in any in stock colour
Wheels rebuilt, meanwhile all joining surfaces are cleaned and ground down where required and sealed using the new best sealant ive found
This is ideal i you want to improve the general appearance of your wheels, ideal if your original lips are fairly presentable
If you require additional work such as mirror polishing this can be done but the price is marginally higher and the turn around time is tripled.
Please get in touch via whatsapp/text
Please visit my page! www.facebook.com/wheelsbycardhore
