would like up BHP till about 300
Tomas_St
Post by Tomas_St »
would like up till 300 BHP
i`ve got standard ecu
and blitz access ecu
HKS FCD + apexi boost controller
550cc injectors
what more i need
1st i think some piggy back ecu
give me recommendations
and jobs what i need to do
Tomas_St
Re: would like up BHP till about 300
Post by Tomas_St »
car is rev2
MR2 Rich
Post by MR2 Rich »
What do you need?
A Rev3 set up. :thumleft:
No 2 :(
Hez
Post by Hez »
Remember the MLS headgasket the original doesn't like 1.0+ bar
Tomas_St
Post by Tomas_St »
on mine is metal gasket
Tomas_St
Post by Tomas_St »
MR2 Rich wrote:What do you need?
which one sensors i need to swap ? for rev3 setups
Tomas_St
Post by Tomas_St »
Map sensor
IAT sensor
MAT sensor
4 wire o2 sensor
water temp sensor
Knock sensor
Injectors
Rev3 ecu
re-pin sockets
what more ?
T.F.S.
Post by T.F.S. »
Hez wrote:Remember the MLS headgasket the original doesn't like 1.0+ bar
Was fine running 20psi+ on mine, how many have you blown?
dazzz wrote:I'm no expert but
Peter Gidden
Post by Peter Gidden »
Doesn't it?
Hez
Post by Hez »
Had one blow on my old rev 2, mate blew his rev 1 was a few years ago mind you. Sure I've seen many more on here in past.
A lot of it might be people saying it just because they heard someone mention it on here.
I'm not saying it will blow, but surely it's nowhere near as strong and forgiving as a mls one?
Peter Gidden
Hez wrote:I'm not saying it will blow, but surely it's nowhere near as strong and forgiving as a mls one?
Rev3 HG is MLS.
And both surfaces need to be properly prepared with new bolts or ARP studs.
Hez
Post by Hez »
Im not sure i phrased that properly, i was originally referring to the stock rev 1&2 gasket where ive seen 2 blow (the original), then saying it might be a good upgrade to put a rev 3 mls gasket on.
vtecpower
Post by vtecpower »
His secret was water meth.. Gained power and kept knock / detonation down. Interesting build read up on his thread.
If I get another turbo charged car (apart from my smart lol) water meth will be a must !!
