How possible would it be to wire the left hand button on the steering wheel to the standard peep peep horn, and the right hand button to some massive truck horn type thing
Thanks,
Sean
TheLepresean wrote:Ah fair enough..
and haha! There's someone with a Bel Air that lives around the corner to me and he has a Dixie horn! Mm, ok I might just change the normal horn out for a loudish horn.
any recommendations?
TheLepresean wrote:That all sounds very complicated to me, partly because I don't understand half of it..
what's a PIC?
TheLepresean wrote:Presumably at some point the wire from each of the buttons join into the one wire that leads to the horn, what I was meaning is would it be possible to sever one of the wires just before this join, extend it and link it to a different larger horn?
shinny wrote:I was in a taxi in Kuala Lumpur once and the driver had rigged up a horn button on the shaft of the gear stick.He drove along with one hand on the wheel and one hand clasping the gear stick, beeping the horn with his little finger at every possible opportunity
synXero wrote:That is brilliant.I want a switch mounted on my gear knob.
I don't really care what it does, I just want one there.
