Advan Neova AD08-R
Advan Neova AD08-R
Am surprised to find that AD08-R tyres do not seem to be available for wheels smaller than 15"
Peter
1989 MR2 Mk1 NA T-bar
1998 Ssangyong Korando GLS
2011 Honda Civic Type R
Re: Advan Neova AD08-R
You can get A048s in 185/55/14 Peter
- Lauren
- IMOC Committee
To be fair, 15's are pretty small these days.
Anything under that and the choice of tyres will always be diminishing.
2020 GR Yaris
- Circuit Pack
SuperRedMR2 wrote:You can get A048s in 185/55/14 Peter
Yes but IIRC AO48 is for use in the dry Alex
Whereas AD08-R is designed for both wet
Peter
- Lauren
- IMOC Committee
Maybe get some lightweight 7-7.5 15's? Then put them on, should be good.
I'd roll with 195/50's.
2020 GR Yaris
- Circuit Pack
Lauren wrote:Maybe get some lightweight 7-7.5 15's? Then put them on, should be good.I'd roll with 195/50's.
Thanks for that Lauren
What make of wheels do you suggest
I don't seem to be able to find any really lightweight ones
AD08-R isn't a lightweight tyre by the way
Peter
elbon50 wrote:SuperRedMR2 wrote:You can get A048s in 185/55/14 Peter
Whereas AD08-R is designed for both wet& dry weather
I used A048 and A032 daily in my charade turbo for like 2 years straight.
In light to medium rain they were fine, heavy rain and standing water is where they fall down.
- Lauren
- IMOC Committee
elbon50 wrote:
What make of wheels do you suggest?
Well to be lightweight they need to be forged really.
Mine weigh in at 7.4kg compared to the standard 17x7s weighing 9.2kg.
2020 GR Yaris
- Circuit Pack
elbon50 wrote:Lauren wrote:Maybe get some lightweight 7-7.5 15's? Then put them on, should be good.I'd roll with 195/50's.
AD08-R isn't a lightweight tyre by the way(about 7KG
http://www.wheelweights.net/
I used to have a set of wedsports on my mk1 in both 14", then 15", but now have Volks TE37s on my mk1
The cast BuddyClub P1 SF 15x6.5s I was looking at weight in at 6.2kg each
£465 from LKPerformance
Lauren wrote:15x7 TE37's are 4.17kg.Pretty light!
They are the way forward Lauren!
- Lauren
- IMOC Committee
Am going to keep an eye out for a set of those for my AE86 I think.
Matching wheels on both my cars would be the way forward!
2020 GR Yaris
- Circuit Pack
