Well I'm back up and running again.
Head gasket must have been leaking between cylinders.
Seems good now but it'll be a good few miles yet before I'll be confident it's fixed.
Why it didn't work first time I'm not sure.
Could have been the old bolts
- they didn't tighten smoothly
(twisting and slip stick).
The 22ftlbs
+90+90 I strongly suspect is enough to get to the bolts yield point.
Second new gasket ended up as BGA
(ordered payen but sent instead), mixed reviews so I guess time will tell.
Interestingly BGA is 1.4 mm vs 1.2 standard.
Instruction required 49ft/lbs in 3 passes
+ retorque after running up to temp for 4age but 22+90+90 for supercharger.
This time I went with the old 49 ft/lbs.
However, out of interest I did torque to 22 and mark the bolts.
Even after re-torque non of the bolts were more than
+90+45.
The two specs are in no way equivalent.
I did also wonder if perhaps the skimmed head had a too good, almost mirror finish, so gave it a light rub with some fine wet and dry also to lessen marks in head from ist Toyota gasket.
