CP Forged Pistons
MR2 Rich
CP Forged Pistons
Post by MR2 Rich »
Is anyone using CP forged pistons in their engine? Having spoken to the main importer for forged pistons today, they say CP are the ones to go for as they are strong and quiet. They are 500 for a set including VAT which I can't find any better elsewhere, anyone got any suggestions on cheapest place for them? Have tried the usual (eBay! fensport and rogue) and they are all more expensive.
Cheers Rich
No 2 :(
Peter Gidden
Re: CP Forged Pistons
Post by Peter Gidden »
All forged pistons are strong. And they're all quiet, excepting maybe HKS.
MR2 Rich
Post by MR2 Rich »
And JE!
No 2 :(
Peter Gidden
MR2 Rich wrote:And JE!
Yep, they're strong and quiet too. Got them in my engine. :thumleft:
MR2 Rich
Post by MR2 Rich »
In mine they sounded like a diesel truck!
No 2 :(
Peter Gidden
MR2 Rich wrote:In mine they sounded like a diesel truck!
Would depend on bore clearance.
ashley
Post by ashley »
You got your bore to piston clearances wrong then :lol:
ashley
Post by ashley »
Dammit...beat me to it!!
MR2 Rich
Post by MR2 Rich »
I didn't, whoever had it before me and did the rebuild got it wrong! I'm having it rebuilt on a standard block and all new Toyota parts to complete it.
No 2 :(
JD
Post by JD »
I have JE and from a cold start there's a little bit of audible slap but that goes once warmed up. As I understand it, forged pistons expand a little bit so bore clearance will have taken this into consideration and leave a little bit of room for the pistons to get up to temp.
ashley
Post by ashley »
None of my forged engines have had piston slap :-k
MR2 Rich
Post by MR2 Rich »
Where did everyone buy their pistons from then? :mrgreen:
No 2 :(
ashley
Post by ashley »
ebay usa...CP's :thumleft:
slipping clutch
Post by slipping clutch »
87mm hks pistons slap when the motor is cold and thats is with the right clearances.
MR2 Rich
Post by MR2 Rich »
ashley wrote:ebay usa...CP's :thumleft:
Cheers Ashley, I will have a look now. Have you got them in your build? :thumleft:
No 2 :(
ashley
Post by ashley »
Yes mate, from a seller called something like PoorBoyParts if I recall correctly, I contacted him outside of ebay and he did me a deal (through PayPal) on ARP's and rods at the same time :thumleft:
jimGTS
Post by jimGTS »
woosner?
kev8611
Post by kev8611 »
I have CP pistons in mine and I cant fault them.
Keep in mind, when ordering, if you were to get standard 86mm (if you can) you may run the risk of them being too tight/loose in your bores due to wear. I was advised not to buy pistons and expect them to fit perfect in the standard bore due to wear.
I got 86.25's then got the block bored to the correct clearance recommended by CP and they are perfect. no different noises from standard
I was 480 for the set. As i say, cant recommend them enough.
Peter Gidden
kev8611 wrote:Keep in mind, when ordering, if you were to get standard 86mm (if you can) you may run the risk of them being too tight/loose in your bores due to wear. I was advised not to buy pistons and expect them to fit perfect in the standard bore due to wear.
Engine builder should be measuring the bores for wear and ovality before ordering pistons.
kev8611
Post by kev8611 »
Yeah sorry missed that bit out. but self explanitory.
Whats the chances of an 86mm fitting as it should in the standard bores?
I was told my bores were fine but got it bored to correct spec for 86.25's using a torque plate just to be sure. Little bit extra power aswell? without pushing the wall thickness of block past safe limits
